WTF
For your information, there is no such thing as a clever bot.
P.S.: Hmmm, the problem is older than I thought; it just got worse recently:
https://forum.videohelp.com/threads/373727-You-have-been-blocked-by-our-clever-bot
Results 1 to 16 of 16
Last edited by El Heggunte; 22nd Sep 2016 at 17:41. Reason: add image; add P.S.; add tag
Increasingly, I've encountered sites that complain if you have adblockers/pop-up blockers and won't advance to the main info section until you disable them.
My response has invariably been: "bye-bye idiots, your info isn't ever going to be THAT vital to me. Not coming back!"
Scott -
In VideoHelp's case, it appears the clever bot thinks the IP address that it's blocking is assigned to a computer that is doing something naughty. The post El Heggunte linked to mentioned a couple of those things.
Some people have indeed done too much scraping, to the point where big chunks of VideoHelp were copied and used to create other websites. It hasn't happened recently, but several years ago, Google and Yahoo would on occasion turn up one of these websites when I was looking for information to answer a question here. I even found some of my own posts, attributed to a different user name. -
The image in post #1 is from a thread that I tried to start in the Test forum.
But what actually triggered the "clever bot" response was my reply in the thread below:
https://forum.videohelp.com/threads/380504-How-can-I-update-x265-encoder-in-Staxrip?p=2...26#post2459826
The original text contained only the URL to LigH's x265 directory @ Mediafire,
nothing more. Conclusion:
if your post or reply is just a hyperlink to somewhere, then you must be a spammer.Last edited by El Heggunte; 18th Sep 2016 at 12:56. Reason: the preview button acted like the post button 0_o
Netscape 5?
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Seamonkey 2.38, actually.
http://cosmicat.com/extensions/titletweak/ -
Me searching for Geraldo Rivera.
https://www.google.com/#q=fox+news+guy+with+mustache
https://www.bing.com/search?q=fox+news+guy+with+mustache&go=Submit&qs=n&form=QBLH&pq=f...9E10CDF39F9DE\
https://duckduckgo.com/?q=fox+news+guy+with+mustache&t=hn&ia=web
https://search.yahoo.com/search;_ylc=X3oDMTFiN25laTRvBF9TAzIwMjM1MzgwNzUEaXRjAzEEc2VjA...p=mss&ei=UTF-8 -
Google generates different query strings, depending on "Javascript.status".
#q=fox+news+guy+with+mustache redirects to Google's ``default´´ when Javascript is disabled...
https://www.google.com/search?hl=en&source=hp&biw=&bih=&q=%22in+order+to+show+you+the+...e+Search&gbv=1 -
But you can post it now?
https://www.mediafire.com/?6lfp2jlygogwa -
ONLY IF the entire text of the post contains anything besides the URL itself
^ Okay, so be it.
But the error message should be clearer... in this case, at least.
"You have been blocked by our clever bot" is unhelpful and misleading
I have now changed the error message so you get some idea what to do.
[SOLVED] "This program is blocked by group policy", Can't install stuff
By Ananymous in forum ComputerReplies: 21Last Post: 26th Nov 2015, 17:09 -
By ecsjjgg in forum FeedbackReplies: 2Last Post: 24th Aug 2015, 16:07 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 13:31 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53
